How to Perform an IBM ThinkPad X60s Fan Spindle Replacement
Выберете то, что вам нужно
  1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement, Fan Spindle: шаг 1, изображение 1 из 1
    • Turn the laptop upside-down, with the battery oriented away.
    • Slide the battery lock switch to the left.
  2. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 2, изображение 1 из 1
    • Complete these steps after disconnecting the laptop from power and after powering the laptop down.
    • Simultaneously complete the following:
    • Slide and hold the battery release switch to the right.
    • Push the battery away from you, out of the back of the laptop.
  3. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 3, изображение 1 из 3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 3, изображение 2 из 3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 3, изображение 3 из 3
    • Unscrew the black 4mm Phillips #2 screw securing the hard drive enclosure cover.
    • Pull the hard drive enclosure cover up and to the left to expose the hard drive caddy.
    • Pull the hard drive caddy out by the plastic pull tab.
  4. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 4, изображение 1 из 3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 4, изображение 2 из 3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 4, изображение 3 из 3
    • Unscrew the two black Phillips #1 screws securing the RAM cover plate.
    • These screws will remain attached to the cover plate.
    • Remove the exposed RAM sticks by prying outward (away from the edges of the RAM sticks) on the securing tabs.
  5. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 5, изображение 1 из 1
    • Unscrew the eleven black 6mm Phillips #1 screws securing the keyboard and palmrest.
    • Flip the laptop over.
  6. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 6, изображение 1 из 2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 6, изображение 2 из 2
    • Push the keyboard backwards (away from yourself) with both hands.
    • Pry your thumb under the mouse buttons to lift the keyboard upwards (away from the work surface).
    • Pull up to detach the keyboard ribbon tab.
  7. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 7, изображение 1 из 2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 7, изображение 2 из 2
    • Pull up to detach the fingerprint scanner ribbon tab.
    • Lift up on the faceplate to remove it.
  8. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 8, изображение 1 из 2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 8, изображение 2 из 2
    • Unscrew the five silver 3mm Phillips #1 screws securing the motherboard.
    • Unscrew the silver 7mm Phillips #1 screw securing the motherboard.
  9. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 9, изображение 1 из 2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 9, изображение 2 из 2
    • (Optional) Lay a piece of paper, or other protective material, over the laptop screen.
    • Flip the motherboard over onto the screen (or protective material).
    • Flipping the motherboard over should not require forceful motion.
    • Take extreme care not to damage any ribbon cables or wires still connected to the motherboard.
  10. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 10, изображение 1 из 3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 10, изображение 2 из 3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 10, изображение 3 из 3
    • Pry back the three metal tabs on the now-exposed underside of the fan housing with needle-nose pliers.
    • Flip the motherboard back over.
  11. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 11, изображение 1 из 2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: шаг 11, изображение 2 из 2
    • Lift the metal housing off of the fan.
    • There may be foil tape securing the housing. If so, remove it carefully in order to put it back after replacing the fan spindle.
    • Remove and replace the fan spindle.
Заключение
Еще один человек закончил это руководство.
Samuel Lees
Участник с: 02/23/15
171 Репутация
1 руководство автора
Команда
Cal Poly, Team 12-2, Green Winter 2015 Участник Cal Poly, Team 12-2, Green Winter 2015
CPSU-GREEN-W15S12G2
6 членов
Автор 13 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 2,395
