How to Reassemble the Palm IIIc
Выберете то, что вам нужно
  1. How to Reassemble the Palm IIIc, How to Reassemble the Palm IIIc: шаг 1, изображение 1 из 1
    • Reinsert the screen into the case that contains the buttons.
  2. How to Reassemble the Palm IIIc: шаг 2, изображение 1 из 1
    • Put the Motherboard back into casing from right to left.
    • Make sure the black clips are securing the motherboard into the casing.
  3. How to Reassemble the Palm IIIc: шаг 3, изображение 1 из 3 How to Reassemble the Palm IIIc: шаг 3, изображение 2 из 3 How to Reassemble the Palm IIIc: шаг 3, изображение 3 из 3
    • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
    • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
  4. How to Reassemble the Palm IIIc: шаг 4, изображение 1 из 2 How to Reassemble the Palm IIIc: шаг 4, изображение 2 из 2
    • Connect the blue and red screen cables to the beige box they were removed from.
  5. How to Reassemble the Palm IIIc: шаг 5, изображение 1 из 2 How to Reassemble the Palm IIIc: шаг 5, изображение 2 из 2
    • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
    • Insert the ZIF tab into the connector box.
    • Gently press down on the flap to secure the ZIF tab in place.
  6. How to Reassemble the Palm IIIc: шаг 6, изображение 1 из 1
    • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
  7. How to Reassemble the Palm IIIc: шаг 7, изображение 1 из 1
    • Place the front and back covers around the casing containing the motherboard and screen.
    • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
    • After the sensor is in place between the two covers, firmly secure the front and back covers.
  8. How to Reassemble the Palm IIIc: шаг 8, изображение 1 из 1
    • Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
    • After the screws are in place, insert the stylus.
  9. How to Reassemble the Palm IIIc: шаг 9, изображение 1 из 1
    • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
Финишная прямая
Еще один человек закончил это руководство.
Angela Arthur
Участник с: 02/16/12
101 Репутация
1 руководство автора
Команда
Ohio State, Team 1-5, Buehl Winter 2012 Участник Ohio State, Team 1-5, Buehl Winter 2012
OSU-BUEHL-W12S1G5
5 членов
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 318
