Введение
Canvas tote bags are meant to be reused, and they are a sustainable alternative to using plastic bags that are mass-produced and not eco-friendly. People often use canvas tote bags for school, groceries, gym, and more! This could include laptops, books, clothes, shoes, etc. Heavy items and natural wear and tear often cause tote bag straps to detach from the tote bag's body.
However, if a strap has detached from your tote bag, it does not mean that you need to discard the tote bag! This is a simple guide to learning how to repair your tote bag by sewing the broken strap back into place to make it as good as new.
Выберете то, что вам нужно
Trim off any loose strings or threads attached to the ends of the strap and tote bag body.
Use a ruler to measure the distance from the end of an attached strap to the edge of the bag.
On the side where the tote bag strap has detached, put a mark based on your previous measurement on the inside of the bag.
Cut a piece of thread that is about 22–24 inches in length.
Pull the thread through the needle eye until the two ends of the thread are equal.
Double knot the two ends of the thread together.
Begin sewing by weaving the needle down through the strap material and then upwards through the strap material.
Sew half an inch above the bottom edge of the tote bag strap in a straight line all the way across to the other end of the strap.
Sew about 2-3 lines with the thread. You may add more or less depending on how much strength you think it will need.
Repeat all of the steps for any remaining detached straps.
