How to Reattach a Metal Rib to Fabric Panel on an Umbrella
Выберете то, что вам нужно
  1. How to Reattach a Metal Rib to Fabric Panel on an Umbrella, How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 1, изображение 1 из 1
    • Open the umbrella and identify any metal ribs that have detached from the fabric panel.
  2. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 2, изображение 1 из 2 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 2, изображение 2 из 2
    • Tie a knot two inches from the end of the thread.
    • Place the opposite end of the thread into a sewing needle.
    • Rubbing or wetting the end of the thread may make it easier to insert the thread into the sewing needle.
  3. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 3, изображение 1 из 1
    • Align the metal rib with the region of the fabric panel that it detached from.
    • If necessary, use scotch tape to secure the metal rib into position so it does not lift up.
  4. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 4, изображение 1 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 4, изображение 2 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 4, изображение 3 из 3
    • Be careful to avoid injury when using a sharp sewing needle.
    • Insert the sewing needle through the umbrella fabric panel and pull the thread through.
    • Poke the sewing needle through the underside of the fabric panel on the opposite side of the metal rib and pull the thread through.
  5. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 5, изображение 1 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 5, изображение 2 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 5, изображение 3 из 3
    • Pull the sewing needle and thread across to wrap around the metal rib.
    • Insert the sewing needle through the fabric panel and pull the thread through.
    • Repeat Steps 4 and 5 until the metal rib is tightly secured to the fabric panel. Three additional loops is recommended.
  6. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 6, изображение 1 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 6, изображение 2 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 6, изображение 3 из 3
    • Remove the thread from the sewing needle.
    • Tie the loose end of the string to the end of the string with the knot from Step 2.
  7. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 7, изображение 1 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 7, изображение 2 из 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: шаг 7, изображение 3 из 3
    • Don't run with scissors!
    • Use scissors to cut off any excess thread.
    • If necessary, remove any scotch tape pieces.
Заключение
Repeat these steps if there are multiple detached metal ribs from the fabric panel. Once the repair is completed, the umbrella should work properly again.
Danielle Shapiro
Участник с: 02/18/20
148 Репутация
1 руководство автора
Команда
UC Davis, Team S2-G5, Andersen Winter 2020 Участник UC Davis, Team S2-G5, Andersen Winter 2020
UCD-ANDERSEN-W20S2G5
4 членов
Автор 2 руководств
Один комментарий
What sort of thread did you use? Yours seems quite thick, a lot thicker than the standard threads.
SBN - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 39
За последние 30 дней: 153
За всё время: 5,598
