Введение
This guide will show you how to reattach a torn or broken apron strap.
A kitchen apron is used for keeping your clothes clean while cooking. It is important to do this replacement because a kitchen apron is a helpful equipment to keep yourself from getting dirty. The straps are especially important to repair because they are the main important part of holding the whole apron together.
Step 4 has a caution, might poke yourself with the sewing needle.
Before beginning make sure all your tools are available to you.
Выберете то, что вам нужно
Use a thread color that matches your article of clothing (or whatever color you like).
Cut a piece of thread around 21 centimeters long.
Insert one side of the thread in the eye of the sewing needle.
Pull the thread to make sure it is in the hole.
Make sure the apron is aligned correctly.
Insert the needle from where you want to start to repair the fabric.
Begin from right to left.
Once inserted, make a knot so the thread can't move. Pull the thread as far as possible but still able to create a knot.
Insert the threaded needle a short distance from where you began, starting again from right to left.
Continue sewing from right to left, starting each new stitch a few centimeters from the previous stitch.
Make sure the thread goes all the way through.
Once you reach the end of the left side, make two small knots.
Begin from the bottom and pull to tighten the knot.
Make sure the apron is aligned correctly and not loose from both sides.
Tug on the strap to make sure it is not loose.
Еще один человек закончил это руководство.
