Введение
This tutorial shows the general steps to take for reattaching the sole of your shoe. Before you start this repair, purchase some shoe repair glue online or from your local shoe store. You should be able to find the other materials around your house.
Выберете то, что вам нужно
Lay several sheets of paper towels down in order to protect the surface you are working on.
Take a Clorox Wipe and thoroughly clean the area where the separation has occurred.
Generously apply glue to both surfaces of the separated shoe.
Wait for about 2 minutes to allow the glue to set before reconnecting the sole.
When the glue application is done, press and hold the sole and the separated surface together in order for the glue to dry.
Stuff an object, such as a 1/2 filled water bottle or newspaper, into the shoe to keep its form.
Stack heavy objects on top of the part of the shoe that is being reconnected.
Remove any excess glue with a Wet rag or moist towelette.
The shoe is now fixed and ready to use.
8 участников успешно повторили данное руководство.
