Введение
If your wood table has been scratched deeply or damaged, use this guide to restore it to near new condition.
Wood tables that are antique can look great. A damaged or scratched wood table may not look appealing to you or your guests. Deeper and/or longer scratches, as well as chipping, are common on some tables.
Before you use this guide, make sure you read your manufacturer's instructions to figure out how to remove the legs from the table.
Since sanding and painting can be demanding on many people's bodies, perform this fast fix in a well-ventilated environment to avoid dust and fumes.
Выберете то, что вам нужно
Get your hex keys or screwdriver.
Using your tool to unscrew all of the legs on the table.
Get the 220 grit sandpaper and cut a smaller piece.
Sand the tabletop until all scratches are leveled with the wood.
Sand all of the legs.
Line up the legs with the screw holes.
Hand tighten the screws and then use the hex keys or screwdriver to completely tighten.
Attach all legs and flip the table onto its legs.
