Введение
This guide will show you how to clean white Adidas Continental 80 shoes.
I’ve had these shoes for about 6 months and obviously, they need cleaning to some degree. I don’t want to spend a lot of money on a detailed shoe cleaner and want to use accessible items to make it easy for everyone that may use this guide. So, I took a quick survey and asked my friends about the ways they’ve cleaned their shoes and a few caught my eye. They all said, “If your shoes are leather, use a toothbrush and scrub it with Dawn soap.” I took their feedback constructively and plan on using the said method for my Adidas Continental 80’s.
Выберете то, что вам нужно
Take the laces out of both shoes before cleaning.
Wet the brush in soapy water.
Brush the base of the shoe horizontally and vertically.
Wet the brush multiple times to keep enough soapy water on the shoe.
Make sure to clean the tongue in the same circular, horizontal, and vertical motions with the toothbrush.
Grab a new bowl with warm water and wet the hand-towel to remove the dirt accumulated by the soapy water.
Wet and wipe multiple times to remove excess soap from the shoe.
Brush the base and sides in the same circular, horizontal, and vertical motions with the toothbrush.
Brush the top and tongue of the left shoe.
Continue rinsing and re-wetting the toothbrush in soapy water.
Soak the laces in the same soapy water you used to clean your shoes for 30-40 minutes.
Having clean shoes is important to a lot of people. Know that this technique is a simple, easy technique with simple materials used. There are plenty of more in-depth, expensive techniques that may clean the shoes a lot better than this technique does.
Еще один человек закончил это руководство.
