Введение
Cat scratching posts will inevitably wear down after a couple of years (or even months) from constant use. Instead of throwing out the whole thing and buying a new one, you can easily revive it with some new sisal rope and make it good as new!
Выберете то, что вам нужно
A worn down cat scratching post is neither fun to look at, nor do cats like it. But this a quick and easy fix that uses minimal materials and tools!
Opal is not amused.
Begin by cutting a section of the existing rope at the top with a utility knife.
Grab onto the cut piece of rope and begin unraveling it. Some sections may be glued down, so don't be shy and give it a good pull to remove the rope.
To save time and rope, you can stop about half-way down, since the bottom portion is likely still in good shape.
When you reach a stopping point, cut the rope with your utility knife and glue the end back onto the post with hot glue.
Take the new sisal rope and glue the end to the post right where the old rope left off.
Every few layers or so, put a dab of hot glue on the post and continue wrapping the rope around the post.
When you get to the top, cut the excess rope off and put one last dab of glue on the post to hold the end of the rope in place.
49 участников успешно повторили данное руководство.
6 Комментариев
I love this idea, but I’m wary of using hot glue to fix the rope to the base - unless the heat from the glue changes the structure of the material (like with foam for example), the hold isn’t very strong in my experience. Have you experimented with other adhesives?
Our hot glue gun from Michaels affixed the sisal rope well when I used thick suede gloves (like gardening or hawk gloves) to hold the glued rope while winding it around the pole. You may need to purchase a hotter temperature glue gun. We had to because our first one didn't work well.
I just bought some sisal rope to do a repair and I agree that hot glue for me is not the ticket. I would prefer to actually tie the rope onto and then off of the stand. Hot glue alone would not be enough I doubt. Just a dab to hold in place while wrapping.
What other adhesives that might work?
Hot glue works just fine if you wrap the rope tightly enough. I have repaired several this way and they have lasted for a couple of years.
