Введение
In this repair, we will be reinforcing a microbead plush by creating a bag for the microbeads. Using this repair, we can extend the duration of items a loved one has given or keep these items in near-perfect condition. Before starting this repair, you should have a spool of a thread in the plush's color to make any repairs unnoticeable. This repair will take a while and can get messy; for example, when flipping the plush casing, use an area that is easy to clean.
Выберете то, что вам нужно
Look for seams in the microbead plush that you can tear to remove its contents.
Using a seam ripper, make a hole the size of your thumb.
Dump out the contents of the plush into a large container using that hole you made.
Fold the inside-out casing in half.
Place it on a piece of fabric folded into fourths. The loose ends of the fabric should be facing you.
Trace the outline of the casing with a marker.
Measure about 20 times the length of the plush in thread.
Push the thread through the eye of the needle until both sides of the needle have an equal amount of thread.
Create a small loop using the loose ends, leaving about 2 centimeters to wrap around the base of the loop. Push the excess through the loop to create a knot.
Unfold the material keeping both outline sheets together.
After unfolding, use a different color marker to note where the hole made in step one is on your plush.
Start stitching along the edge of the outlines, weaving the needle every centimeter to close any gaps.
Stuff the bag into the plush, leaving the openings together.
Sew the edges of the openings onto the plush to prevent the bag from slipping when refilling.
Insert the funnel in the opening and begin refiling the plush.
After refilling the plush, sew the opening closed.
After closing the opening press down on the plush to spread around the microbeads.
With those final stitches, your microbead plush shouldn’t spill anymore.
