Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the mounting screws from the thumb-turn side of the lock assembly using a Phillips screwdriver.
Remove the retaining clip from the back of the cylinder assembly using tweezers or pliers.
Remove the spring cover with the cylinder in the upright position using a Flathead screwdriver.
Remove the springs carefully with tweezers or pliers and set the springs aside as they will need to be put back in during reassembly.
Remove the plug from the cylinder assembly in the upright position so the bottom pins do not fall out.
Remove the bottom pins from the plug. This can be done easily by turning over the plug and dumping them out.
Place the bottom pins into the pin holes until the top of the new pin matches the shear line.
16 участников успешно повторили данное руководство.
5 Комментариев
worked according to the instructions
Huh?? What do you do after the last instruction?
Follow the instructions in reverse order starting from step 8.
Worked exactly as described. Watch those springs! They fly out easily, and are prone to bend when reinstalled.
