How to Remove Calcium Buildup from a Shower Head
Выберете то, что вам нужно
  1. How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: шаг 1, изображение 1 из 2 How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: шаг 1, изображение 2 из 2
    • Using an adjustable wrench, loosen the bolt that attaches the shower head to the wall spout by turning the wrench counterclockwise.
    • You may be able to loosen the shower head by hand.
    • Handle carefully because the shower head may be heavy.
  2. How to Remove Calcium Buildup from a Shower Head: шаг 2, изображение 1 из 1
    • Use your hands to finish unscrewing the bolt.
    • Remove the shower head from the wall spout.
  3. How to Remove Calcium Buildup from a Shower Head: шаг 3, изображение 1 из 3 How to Remove Calcium Buildup from a Shower Head: шаг 3, изображение 2 из 3 How to Remove Calcium Buildup from a Shower Head: шаг 3, изображение 3 из 3
    • Pour one cup of water into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the water.
  4. How to Remove Calcium Buildup from a Shower Head: шаг 4, изображение 1 из 3 How to Remove Calcium Buildup from a Shower Head: шаг 4, изображение 2 из 3 How to Remove Calcium Buildup from a Shower Head: шаг 4, изображение 3 из 3
    • Pour one cup of distilled vinegar into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the solution.
    • If using the vinegar solution provided in steps 3 and 4 fails to provide adequate results, you may want to repeat the steps using CLR (Calcium, Lime, and Rust) solution instead.
  5. How to Remove Calcium Buildup from a Shower Head: шаг 5, изображение 1 из 2 How to Remove Calcium Buildup from a Shower Head: шаг 5, изображение 2 из 2
    • Place the shower head face down into the plastic bag of vinegar solution.
    • Let the shower head sit for one hour before removing it from the plastic bag of vinegar solution.
  6. How to Remove Calcium Buildup from a Shower Head: шаг 6, изображение 1 из 1
    • After one hour, remove the shower head from the plastic bag of vinegar solution.
    • Use a metal sponge to scrub in a circular motion to remove the treated calcium on the shower head.
    • Excessive scrubbing could damage the finish.
  7. How to Remove Calcium Buildup from a Shower Head: шаг 7, изображение 1 из 2 How to Remove Calcium Buildup from a Shower Head: шаг 7, изображение 2 из 2
    • Place the shower head under running water to remove any extra calcium left behind.
    • If calcium is still present, repeat steps 5 through 7 as needed.
  8. How to Remove Calcium Buildup from a Shower Head: шаг 8, изображение 1 из 2 How to Remove Calcium Buildup from a Shower Head: шаг 8, изображение 2 из 2
    • Clamp the adjustable wrench onto the bolt of the shower head.
    • Turn the adjustable wrench clockwise to tighten the shower head back onto the water spout.
Финишная черта
3 участников успешно повторили данное руководство.
Jacob Abrego
Участник с: 02/23/16
150 Репутация
1 руководство автора
Команда
Texas Tech, Team 26-6, Rauch Spring 2016 Участник Texas Tech, Team 26-6, Rauch Spring 2016
TTU-RAUCH-S16S26G6
3 членов
Автор 4 руководств
Один комментарий
How to remove rust stain (from iron) from bathroom tiles?
waihong yeung - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 28
За последние 30 дней: 76
За всё время: 9,227
