How to Remove Scratches from a Car's Interior
Выберете то, что вам нужно
  1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: шаг 1, изображение 1 из 2 How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: шаг 1, изображение 2 из 2
    • Clean the area around the scratch with the interior cleaner.
    • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
    Спросите у FixBot
    Добавить комментарий
  2. How to Remove Scratches from a Car's Interior: шаг 2, изображение 1 из 2 How to Remove Scratches from a Car's Interior: шаг 2, изображение 2 из 2
    • Using the heat gun, gently apply heat to the plastic until it begins to soften.
    • Don't leave it on too long or else the plastic will burn and warp.
    • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
    Спросите у FixBot
  3. How to Remove Scratches from a Car's Interior: шаг 3, изображение 1 из 1
    • Apply the grain pad to the intended area using light pressure.
    • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
    • Make sure you use a grain pad that closely resembles the trim of your car.
    Спросите у FixBot
  4. How to Remove Scratches from a Car's Interior: шаг 4, изображение 1 из 1
    • Let the area cool and harden.
    • The texture should now look similar to the unaffected area.
    Спросите у FixBot
  5. How to Remove Scratches from a Car's Interior: шаг 5, изображение 1 из 1
    • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
    Спросите у FixBot
  6. How to Remove Scratches from a Car's Interior: шаг 6, изображение 1 из 1
    • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
    Спросите у FixBot
Заключение
By following these steps you will be able to remove scratches from your cars interior.
Еще один человек закончил это руководство.
Ryan Vogt
Участник с: 10/08/20
180 Репутация
1 руководство автора
Команда
Linn Benton Community College, Team S1-G18, Johnson Fall 2020 Участник Linn Benton Community College, Team S1-G18, Johnson Fall 2020
LBCC-JOHNSON-F20S1G18
1 член
Автор 6 руководств
5 Комментарии к руководству
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - Ответить Поделиться
Any luck finding “grain texture” pads?
ChrisB - Ответить Поделиться
i cant find any Grain pads / stamps online
Flow_Fire - Ответить Поделиться
have someone tried this trick and made it work?
Munir Ahmed - Ответить Поделиться
Ustedes hacen este trabajo
Emely Caraballo - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 50
За последние 7 дней: 326
За последние 30 дней: 1,615
За всё время: 142,533
