How to Remove a SIM from Samsung Galaxy S7, if inserted without tray
Выберете то, что вам нужно
  1. How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Back Glass: шаг 1, изображение 1 из 3 How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Back Glass: шаг 1, изображение 2 из 3 How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Back Glass: шаг 1, изображение 3 из 3
    • Set your hot air gun to your adhesive melting temperature. (I use 250)
    • heat up the four sides of the back glass to a decent temperature.
    • use a suction cup to apply upwards pressure. this begins to lift the glass when warm.
    • apply Ethyl Alcohal (99%) to the seam, to help break down the adhesive.
  2. How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Housing Panels: шаг 2, изображение 1 из 3 How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Housing Panels: шаг 2, изображение 2 из 3 How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Housing Panels: шаг 2, изображение 3 из 3
    • Once the back glass is removed, Begin removing the screws from the three housing panels
    • After removing all of the screws, the panels are clipped into the frame. A little bit of pressure with a spudger/pick will remove them with ease
    • remove the three panels to gain full acces to the motherboard.
  3. How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Motherboard from frame: шаг 3, изображение 1 из 2 How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Motherboard from frame: шаг 3, изображение 2 из 2
    • The SIM tray is located on the other side of the motherboard.
    • In order to get there, lifr all of the connectors attached to the board. (Camera, Screen, Power button, Network Coaxials, Fingerprint Sensor, Earspeaker, Prox/Light Sensors, Volume Buttons)
    • When Lifting board, be sure to lift at the top, as the Charge port is connected at the bottom. As you lift the board out, disconnect the Charge flex
  4. How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Card from Reader: шаг 4, изображение 1 из 2 How to Remove a SIM from Samsung Galaxy S7, if inserted without tray, Remove Card from Reader: шаг 4, изображение 2 из 2
    • Use small Slot Screwdriver, to access openings in reader, and slowly glide sim outwards.
    • Get the sim card out enough to comforably grab hold, and remove sim from device.
    • while using metal tools to operate on board, be sure there is no power to board, Destatic each tool, and BE GENTLE
    • Follow the steps bacwards to reassemble the device
    • you may encounter a situation where replacement adhesive is needed to re-apply the back housing
Заключение
8 участников успешно повторили данное руководство.
Scott
Участник с: 10/09/13
10 006 Репутация
Автор 4 руководств
2 Комментариев
would i use this method to remove broken sim tray piece stuck in the slot? in my s7 the sim card tray broke near the bottom so now i have the bottom of the tray stuck inside the phone and didnt want to shove anything in it before doing research.
Is there a way to maybe fish it out without opening the phone? (sim card isnt in the phone. only bottom part of tray broke off for no reason, especially that in 2 years it got opened 3 times total and closed very carefully.)
Diablofredd - Ответить
Thanks for the how-to fix. It really worked.
Ojoma - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 39
За всё время: 21,481
