Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Инструменты
Запчасти
Детали не указаны.
  1. Этот шаг не переведен. Помогите перевести
    Make sure that the motor is off and has had time to cool after being used. Push in the clips on the top of the cover, and remove the cover.
    • Make sure that the motor is off and has had time to cool after being used.
    • Push in the clips on the top of the cover, and remove the cover.
  2. Этот шаг не переведен. Помогите перевести
    Make a note of the position of the filter, and remove the cover.
    • Make a note of the position of the filter, and remove the cover.
  3. Этот шаг не переведен. Помогите перевести
    Lightly bend the filter so that you can see all surfaces of the filter.
    • Lightly bend the filter so that you can see all surfaces of the filter.
  4. Этот шаг не переведен. Помогите перевести
    Use compressed air to blow out dirt or dust particles from the air filter.
    • Use compressed air to blow out dirt or dust particles from the air filter.
    • You can bend it in several places to make sure you clean between each of the fins.
  5. Этот шаг не переведен. Помогите перевести
    Seat the filter in the same position you made a note of in Step 2.
    • Seat the filter in the same position you made a note of in Step 2.
    • If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
    • Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
  6. Этот шаг не переведен. Помогите перевести
    Push the clips of the cover in until they click. Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
    • Push the clips of the cover in until they click.
    • Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
Финишная черта
Еще один человек закончил это руководство.
Pearce McKee
Участник с: 31.03.2020
133 Репутация
1 руководство автора
Команда
University of Memphis, Team S5-G1, Willis Spring 2020 Участник University of Memphis, Team S5-G1, Willis Spring 2020
UM-WILLIS-S20S5G1
2 членов
Автор 1 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 235
