How to Repair A Damaged Book Cover
Выберете то, что вам нужно
  1. How to Repair A Damaged  Book Cover, How to Repair A Damaged  Book Cover: шаг 1, изображение 1 из 1
    • Lay the ConTact Paper on a smooth, clean surface.
    • Make sure the adhesive side is face down so that the white paper is facing you.
    • Place your book on the ConTact paper.
  2. How to Repair A Damaged  Book Cover: шаг 2, изображение 1 из 1
    • Wrap the ConTact Paper over your book, measuring out enough to completely cover the book.
  3. How to Repair A Damaged  Book Cover: шаг 3, изображение 1 из 1
    • Place a paperweight on the side of the folded paper to prevent curling. Or even the scissors you're using (as shown) to hold down the corner of the paper.
    • Flatten the edge of the ConTact Paper along the spine of your book.
  4. How to Repair A Damaged  Book Cover: шаг 4, изображение 1 из 1
    • Cut the ConTact Paper from the roll, keeping to the length measured to cover your entire book.
  5. How to Repair A Damaged  Book Cover: шаг 5, изображение 1 из 3 How to Repair A Damaged  Book Cover: шаг 5, изображение 2 из 3 How to Repair A Damaged  Book Cover: шаг 5, изображение 3 из 3
    • Once the extra ConTact Paper is discarded, cut the ConTact Paper diagonally towards the spine of your book.
    • Repeat this cut on the other side of the spine.
    • Your finished cut should have a 'v' shape pointing towards the spine of the book
  6. How to Repair A Damaged  Book Cover: шаг 6, изображение 1 из 3 How to Repair A Damaged  Book Cover: шаг 6, изображение 2 из 3 How to Repair A Damaged  Book Cover: шаг 6, изображение 3 из 3
    • With the cover of your book laying flat against the left side of the paper, peel back the right half of the paper from the laminate film.
    • Make sure to peel the paper back until the focal point of the 'V' is exposed.
    • Fold the edge of the laminate film onto the table to prevent sliding and bubbles.
  7. How to Repair A Damaged  Book Cover: шаг 7, изображение 1 из 3 How to Repair A Damaged  Book Cover: шаг 7, изображение 2 из 3 How to Repair A Damaged  Book Cover: шаг 7, изображение 3 из 3
    • Place the top edge of your book to the top edge of the center of the laminate film.
    • Using a rolling motion, slowly stick the rest of the spine to the laminate.
    • Using the same motion, slowly roll one side of the textbook over the exposed film.
    • Roll onto the laminate slowly and evenly to prevent bubbles in your lamination.
  8. How to Repair A Damaged  Book Cover: шаг 8, изображение 1 из 2 How to Repair A Damaged  Book Cover: шаг 8, изображение 2 из 2
    • Unfold the laminate from the table and cut to the edges similar to Step 4
    • The finished edges will look like an inverted 'v'
  9. How to Repair A Damaged  Book Cover: шаг 9, изображение 1 из 3 How to Repair A Damaged  Book Cover: шаг 9, изображение 2 из 3 How to Repair A Damaged  Book Cover: шаг 9, изображение 3 из 3
    • Fold the edges onto the inside cover of the textbook. Start with the top of the book cover, folding the vertical edge of the book last.
  10. How to Repair A Damaged  Book Cover: шаг 10, изображение 1 из 3 How to Repair A Damaged  Book Cover: шаг 10, изображение 2 из 3 How to Repair A Damaged  Book Cover: шаг 10, изображение 3 из 3
    • Remove the rest of the paper from the laminate film.
    • Repeat motions from step 7 and slowly roll your book cover onto the laminate film.
  11. How to Repair A Damaged  Book Cover: шаг 11, изображение 1 из 3 How to Repair A Damaged  Book Cover: шаг 11, изображение 2 из 3 How to Repair A Damaged  Book Cover: шаг 11, изображение 3 из 3
    • Repeat steps 8 and 9 to cut and secure lamination.
    • Trim any remaining lamination film to complete the project.
Заключение
If you have followed the previous steps, your textbook should now be mended and resistant to further damage.
Еще один человек закончил это руководство.
Stephaney Ferguson
Участник с: 03/15/17
125 Репутация
1 руководство автора
Команда
Missouri Western, Team S40-G7, Kunkel Spring 2017 Участник Missouri Western, Team S40-G7, Kunkel Spring 2017
MWSU-KUNKEL-S17S40G7
2 членов
Автор 2 руководств
Один комментарий
The original cover was completely destroyed by water and am unable to follow your instructions. Can't I just purchase a new cover?
ryanmary - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 23
За последние 30 дней: 139
За всё время: 16,609
