Введение
If you have a hole or rip in your curtains, follow this guide. Our simple instructions provide a way for people to repair and save their curtains for further use.
No special skills are required. All that is needed is an iron and ironing board. Be careful when using the iron as it can burn your skin and the fabric.
By following this guide, you won’t have to get rid of your favorite curtains, you can save some money, and reduce waste!
Выберете то, что вам нужно
Examine the hole and open it gently so as to not cause any tearing.
Cut any loose threads that have frayed around the tear.
Preheat the iron to the temperature stated on the instructions for the fusible interfacing.
Now your curtain is as good as new! Fusible interfacing cannot be removed once it is attached to the fabric, so be careful when applying it so you can repair your curtains successfully.
