How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On
Выберете то, что вам нужно
Видео обзор
  1. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: шаг 1, изображение 1 из 1
    • As you can see from the photo, the negative pole of the battery is connected to the main board through the aluminum body of the keyboard.
    • There are two contact areas:
    • Between the battery cover and the KB aluminum body
    • Between the power button assemble and the KB aluminum body
    • If the device has a power problem, we need to check and clean these two places
  2. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: шаг 2, изображение 1 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: шаг 2, изображение 2 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: шаг 2, изображение 3 из 3
    • Use a Coin to remove the metal battery screw cover
    • Change the batteries (AA) and test the keyboard
    • If the keyboard does not work, go to the next step
  3. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: шаг 3, изображение 1 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: шаг 3, изображение 2 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: шаг 3, изображение 3 из 3
    • Use cotton buds, Toothpicks and Isopropyl Alcohol to clean the contact area and the battery cap.
    • Test the device and f the keyboard does not work, go to the next step
  4. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: шаг 4, изображение 1 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: шаг 4, изображение 2 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: шаг 4, изображение 3 из 3
    • Remove the plastic cap from the middle on the tube and disconnect the KB flex cable
    • There are a screw secured the BT antenna, remove it
    • Slide the board out.
    • Be careful for the KB Flex Cable
  5. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: шаг 5, изображение 1 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: шаг 5, изображение 2 из 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: шаг 5, изображение 3 из 3
    • Use tweezers or a sharp metal tool and slightly bend the contact plate outwards
    • Clean the tube and the contact plate
    • Install back the logic board plate and be careful for the flex
Заключение
5 участников успешно повторили данное руководство.
ZFix
Участник с: 12/09/13
191 308 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 535 руководств
4 Комментариев
Add a little dielectric grease to the battery end cap. Had considerable corrosion despite batteries not leaking. Strange design.
George Walsh - Ответить
Wow! This fixed actually worked! I was about to thrown this A1314 keyboard out (2009 model)! You can remove the plastic "cap" with a precision flathead screwdriver. Also, be careful when disassembling the ribbon cable - there is a plastic retaining clip holding it in place. Use the precision screwdriver to carefully release the tabs on either side and then pop it out. The ribbon cable will then easily side out. By the way...I'm typing this comment on my newly fixed wireless keyboard! Thanks again!
Vic - Ответить
its great having this guide. I got the keyboard to work again.
shinnranchgrouse - Ответить
from time to time it makes error sound and interfering apps such as blinking pop up menus ... speaking about MacBook Pro 2017 Monterey
Not to mention that it's not connecting to MacBook Air M1 at all ... )) Goodby my 2009 bluetooth .. Sad ..It is like new and working with other apps except adobe )
Alec - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 49
За последние 30 дней: 212
За всё время: 13,612
