Выберете то, что вам нужно
Видео обзор
As you can see from the photo, the negative pole of the battery is connected to the main board through the aluminum body of the keyboard.
There are two contact areas:
Between the battery cover and the KB aluminum body
Between the power button assemble and the KB aluminum body
If the device has a power problem, we need to check and clean these two places
Use a Coin to remove the metal battery screw cover
Change the batteries (AA) and test the keyboard
If the keyboard does not work, go to the next step
Use cotton buds, Toothpicks and Isopropyl Alcohol to clean the contact area and the battery cap.
Test the device and f the keyboard does not work, go to the next step
Remove the plastic cap from the middle on the tube and disconnect the KB flex cable
There are a screw secured the BT antenna, remove it
Slide the board out.
Hope this helps someone in the future. I found that if you place your thumbs against the side of the plastic on the "inside" of the keyboard and push towards the "outside" that it will pop off. There are some delicate plastic latches that may break off, though.
5 участников успешно повторили данное руководство.
4 Комментариев
Add a little dielectric grease to the battery end cap. Had considerable corrosion despite batteries not leaking. Strange design.
Wow! This fixed actually worked! I was about to thrown this A1314 keyboard out (2009 model)! You can remove the plastic "cap" with a precision flathead screwdriver. Also, be careful when disassembling the ribbon cable - there is a plastic retaining clip holding it in place. Use the precision screwdriver to carefully release the tabs on either side and then pop it out. The ribbon cable will then easily side out. By the way...I'm typing this comment on my newly fixed wireless keyboard! Thanks again!
its great having this guide. I got the keyboard to work again.
from time to time it makes error sound and interfering apps such as blinking pop up menus ... speaking about MacBook Pro 2017 Monterey
Not to mention that it's not connecting to MacBook Air M1 at all ... )) Goodby my 2009 bluetooth .. Sad ..It is like new and working with other apps except adobe )
