How to Repair Broken Makeup Powder
Выберете то, что вам нужно
  1. How to Repair Broken Makeup Powder, How to Repair Broken Makeup Powder: шаг 1, изображение 1 из 2 How to Repair Broken Makeup Powder, How to Repair Broken Makeup Powder: шаг 1, изображение 2 из 2
    • Set a paper towel down on your workspace to catch any spills during the repair process.
    • Using the toothpick, break up the powder into smaller pieces to ensure that all the product is lifted off of the container that it is held in.
  2. How to Repair Broken Makeup Powder: шаг 2, изображение 1 из 1
    • Dump the broken powder into a bowl, and tap on the side of the bowl to make sure that all the product is falling in.
    • Using the cotton swab, wipe off as much of the remaining product as possible into the bowl.
  3. How to Repair Broken Makeup Powder: шаг 3, изображение 1 из 1
    • Add 3 drops of isopropyl alcohol into the bowl of powder.
  4. How to Repair Broken Makeup Powder: шаг 4, изображение 1 из 1
    • Start mixing the powder and isopropyl alcohol together with the spoon.
    • Continue to add 3 drops of isopropyl alcohol to the bowl at a time until all the powder is wet.
  5. How to Repair Broken Makeup Powder: шаг 5, изображение 1 из 1
    • Clean the container with paper towels and isopropyl alcohol. This will make sure that the completed project will be looking good as new.
    • Scoop all of the product into the spoon and pour it into the clean container.
  6. How to Repair Broken Makeup Powder: шаг 6, изображение 1 из 1
    • Once all of the product is in the container, smooth down the surface with your finger. Try to soften as many of the bumps as possible.
  7. How to Repair Broken Makeup Powder: шаг 7, изображение 1 из 1
    • Use the paper towel to clean up the edges of the container.
    • Let the finished product harden by keeping it unopened for 24-48 hours near a window. Then it will be ready to use.
Заключение
The reader will be able to reassemble their broken makeup powder by reading this easy-to-follow tutorial.
Еще один человек закончил это руководство.
Cloe Chin
Участник с: 04/10/19
169 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S25-G5, Crane Spring 2019 Участник Eastern Washington University, Team S25-G5, Crane Spring 2019
EWU-CRANE-S19S25G5
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 519
