Введение
If the rotors will not turn on your RC Heli and it will not take off, you might have knocked one of the engine conversion gears out of place. Easily access the gear box of your helicopter and repair it with this easy fix.
Выберете то, что вам нужно
Locate the problematic engine gear inside the helicopter frame.
Unscrew the decorative/protective shroud blocking your access to the inside of the helicopter.
If it is possible to reset the gear without unscrewing further, attempt to push the gear back up into place on the motor shaft with a screwdriver or your finger.
Place the screwdriver's tip underneath the clear motor gear.
Firmly push the gear back up into place so that it correctly connects with the main rotor gear.
Return all the pieces to their original place inside the frame.
Screw the frame tightly back into place.
Test the helicopter for functionality.
If it works then the helicopter is fixed and you can screw the shroud back into place.
To reassemble, after testing for functionality, make sure all inner parts are back in their original location. Screw the frame and shroud tightly back in place.
5 участников успешно повторили данное руководство.
2 Комментариев
Amazing! That repair was genuinely simple to follow directions helped me step by step and I fixed my helicopter for my grandson
