Введение
Binoculars are somewhat delicate, and when used outdoors in dynamic settings, they can sometimes sustain damage, which can knock the two sides out of alignment, culminating in double vision. Small changes in the positioning of the prisms can result in significant differences in the vision of the binoculars, and binocular manufacturers often hide the adjustment screws to discourage owners from attempting to repair them on their own. This guide will demonstrate how to find the adjustment screws on a pair of Barska 10x50 WA binoculars and adjust them to align the double vision.
Выберете то, что вам нужно
Remove the main J0 head screw in the center of the binoculars, using the driver with the 4 mm bit and J0 attachment.
Pry apart the rear rubber covering on each side to expose the two back prism adjustment screws.
Adjust the two front 1.5 mm flat head prism screws with small turns.
Look through the binoculars after each adjustment to see if it is aligning the vision, and repeat the adjustments until it is repaired.
3 участников успешно повторили данное руководство.
