How to Repair Frayed Shoelaces
Выберете то, что вам нужно
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: шаг 1, изображение 1 из 1
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: шаг 2, изображение 1 из 3 How to Repair Frayed Shoelaces: шаг 2, изображение 2 из 3 How to Repair Frayed Shoelaces: шаг 2, изображение 3 из 3
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: шаг 3, изображение 1 из 2 How to Repair Frayed Shoelaces: шаг 3, изображение 2 из 2
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: шаг 4, изображение 1 из 3 How to Repair Frayed Shoelaces: шаг 4, изображение 2 из 3 How to Repair Frayed Shoelaces: шаг 4, изображение 3 из 3
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: шаг 5, изображение 1 из 1
    • Repeat these steps on all the other frayed shoelaces.
Заключение
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14 участников успешно повторили данное руководство.
Anirudh Jain
Участник с: 04/09/15
605 Репутация
1 руководство автора
Команда
Cal Poly, Team 28-6, Green Spring 2015 Участник Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 13
За последние 30 дней: 63
За всё время: 11,760
