How to Repair Molded Baseboards
Выберете то, что вам нужно
  1. How to Repair Molded Baseboards, How to Repair Molded Baseboards: шаг 1, изображение 1 из 1
    • Sand the damaged area with the 120 grit sandpaper or a sanding block.
    • Use a utility knife to smooth rougher areas if needed.
  2. How to Repair Molded Baseboards: шаг 2, изображение 1 из 1
    • Lightly coat the damaged area with wood glue.
  3. How to Repair Molded Baseboards: шаг 3, изображение 1 из 2 How to Repair Molded Baseboards: шаг 3, изображение 2 из 2
    • Build up the affected areas with the wood filler. This can be applied with your hands (as individual product safety allows), a spare piece of cardboard, or a popsicle stick.
    • Allow to dry a few hours or overnight (based on product directions).
  4. How to Repair Molded Baseboards: шаг 4, изображение 1 из 1
    • Cut or fold the 150 grit sandpaper sheet into various pieces to allow proper fit into the various grooves of your baseboard.
  5. How to Repair Molded Baseboards: шаг 5, изображение 1 из 1
    • Sand the dried wood filler with 150 grit sandpaper.
    • Start from the inside of the baseboard and move out toward the repaired area.
    • Avoid a sawing or back-and-forth motion with the sandpaper to achieve a smooth finish.
  6. How to Repair Molded Baseboards: шаг 6, изображение 1 из 1
    • Wipe with a slightly damp cloth.
    • Repeat step 3 as needed.
    • Wait at least one hour.
    • Repeat step 6 for the final sanding.
  7. How to Repair Molded Baseboards: шаг 7, изображение 1 из 1
    • Touch-up with matching paint as needed.
Заключение
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
2 участников успешно повторили данное руководство.
Melanie M. Alter
Участник с: 09/23/21
199 Репутация
1 руководство автора
Команда
University of North Texas, Team 1-2, Friess Fall 2021 Участник University of North Texas, Team 1-2, Friess Fall 2021
UNT-FRIESS-F21S1G2
1 член
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 77
За последние 30 дней: 326
За всё время: 7,781
