Введение
After no clear guide on options for fixing this common issue, this was created.
Инструменты
Запчасти
Никакие детали не требуются.
  1. First, check fuses and see if any are out. At times other fuses and issues trip more issues. If all good, check circuit breakers located under dash on drivers side.
    • First, check fuses and see if any are out. At times other fuses and issues trip more issues.
    • If all good, check circuit breakers located under dash on drivers side.
    • Circuit breakers labeled: (Power) 30A and (Automatic Shoulder Belt) 30A may be tripped. This is a simple fix. Just by sticking a toothpick or needle in hole located on circuit breaker (see 2nd photo). If it clicks, it may have been tripped and you journey may end here, if not then continue.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. If you were like me, it was not as simple as a fuse or breaker. You may need to check your wires coming from the switches on the door, specifically in the door jam. Due to age and wear, you may have a tear (mix-tape dropping soon). OR like mine, many torn wires.
    • If you were like me, it was not as simple as a fuse or breaker. You may need to check your wires coming from the switches on the door, specifically in the door jam.
    • Due to age and wear, you may have a tear (mix-tape dropping soon). OR like mine, many torn wires.
    • Here you need to remove the rubber cover and may need to push wires through kick panel to work on/check wires.
  4. As shown, wires break and simply reconnecting them will restore your windows, seat belt, and/or lock issues.
    • As shown, wires break and simply reconnecting them will restore your windows, seat belt, and/or lock issues.
    • Make sure to reconnect and reassemble everything. Hope this guide helped!
Заключение
2 участников успешно повторили данное руководство.
Ricky
Участник с: 17.09.2013
756 Репутация
Автор 3 руководств
Команда
TechTucson WeFixThat Member of TechTucson WeFixThat
Community
2 членов
Автор 4 руководств
Комментариев: 2
Great to see it first hand. I’m thinking about not risking it and going with a service for my seat belt repair like this one https://www.safetyrestore.com/seat-belt-... .. its much more affordable than a dealership.. any experience with mail in services like this?
David Melnichuk - Ответить
David Melnichuk: It appears that that service is in MA, and of course can deal with an issue if you have a part that you can send to them. I am in Seattle, and it’s a seat belt fold-over issue repeatedly interfering with good operation. safetyrestore doesn’t have nationwide branches, does it?
danielbaker2 - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 19
За 30 дней: 90
За всё время: 7,911
