How to Repair Warped Eyeglasses Arm Joint and Replace the Screw
Выберете то, что вам нужно
  1. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 1, изображение 1 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 1, изображение 2 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 1, изображение 3 из 3
    • Select a screw from the assorted eyeglasses screws box to begin the size-fitting process.
    • Start from the smaller sizes and work your way up until the screw body fits in the eyeglass frame hinge.
  2. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 2, изображение 1 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 2, изображение 2 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 2, изображение 3 из 3
    • Place the screw into the end piece of the eyeglasses.
    • If the screw does not fit, repeat Steps 1 and 2 until you find a match.
    • Set the screw aside once you have the perfect fit.
  3. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 3, изображение 1 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 3, изображение 2 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 3, изображение 3 из 3
    • Position the pliers so that both sides of the arm joint are on the inside of the pliers.
    • Apply slight pressure to the pliers to bend the warped arm joint back into place.
    • Too much pressure might break the arm joint or make the arm joint too tight for the next step, so be very mindful about the pressure!
  4. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 4, изображение 1 из 2 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 4, изображение 2 из 2
    • Align the arm joint to the end piece of the eyeglasses.
    • If the two pieces do not align or the fit is too loose, repeat Step 3 to adjust the arm joint.
  5. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 5, изображение 1 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 5, изображение 2 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 5, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • Place the screw through the arm joint and end piece using tweezers.
  6. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 6, изображение 1 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 6, изображение 2 из 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: шаг 6, изображение 3 из 3
    • Tighten the screw with the screwdriver.
    • Depending on your eyeglasses screws, choose the appropriate screwdriver size and shape.
Заключение
To disassemble your device, follow these instructions in reverse order.
Jaclyn Nguyen
Участник с: 02/01/23
133 Репутация
1 руководство автора
Команда
UC Davis, Team 4-4, Andersen Winter 2023 Участник UC Davis, Team 4-4, Andersen Winter 2023
UCD-ANDERSEN-W23S4G4
3 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 18
За последние 30 дней: 74
За всё время: 952
