How to Repair Wood Dents with Wood Filler
Выберете то, что вам нужно
  1. How to Repair Wood Dents with Wood Filler, How to Repair Wood Dents with Wood Filler: шаг 1, изображение 1 из 1
    • Inspect the damage in the wood and determine how much wood filler will be needed.
    • A shallow dent in the wood will require less wood filler than a dent with deeper damage.
  2. How to Repair Wood Dents with Wood Filler: шаг 2, изображение 1 из 1
    • Smooth the surface where the damage was by scraping off the splinters using a 50 mm wide putty knife blade.
    • Use the corner of the blade to smooth over the bumps.
  3. How to Repair Wood Dents with Wood Filler: шаг 3, изображение 1 из 1
    • Apply Elmer's Carpenter's Color Change Wood Filler to the putty knife and smear onto the surface.
    • An 8 ounce can of Elmer's Wood Filler will suffice for many repairs.
  4. How to Repair Wood Dents with Wood Filler: шаг 4, изображение 1 из 1
    • Allow the filler to dry.
    • Shallow damages can take thirty minutes to an hour to dry.
    • Deep damages take up to two hours.
  5. How to Repair Wood Dents with Wood Filler: шаг 5, изображение 1 из 1
    • Sand the dry surface using a 3M 75 mm wide fine-grit sandpaper.
    • Before sanding the surface, make sure the wood filler has dried by touching the wood filler.
  6. How to Repair Wood Dents with Wood Filler: шаг 6, изображение 1 из 2 How to Repair Wood Dents with Wood Filler: шаг 6, изображение 2 из 2
    • Apply Minwax Wood Finish Stain to the wood using a 25 mm stain brush.
    • Allow the stain to soak the surface for a few minutes so the wood absorbs it well.
    • An 8 ounce can of stain will suffice for this repair.
    • Optional: The 25 mm stain brush can be replaced with a regular 25 mm cloth brush found at home.
    • Multiple coats may be applied to reach the desired color.
  7. How to Repair Wood Dents with Wood Filler: шаг 7, изображение 1 из 1
    • Optional: Paint the surface with white paint from a can of Rust-Oleum if the stain is not the desired color for the surface.
    • Use a 25 mm paint brush and an 8 ounce can of Rust-Oleum.
    • Multiple coats map be applied to reach the desired color.
  8. How to Repair Wood Dents with Wood Filler: шаг 8, изображение 1 из 1
    • Dry the surface by patting the surface with a cloth towel.
Заключение
If the damage is still visible, then follow steps 1 through 8 again until the damaged area matches the rest of the wood. I hope this guide was helpful!
Nicole See
Участник с: 01/16/17
161 Репутация
1 руководство автора
Команда
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 Участник USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017
USFSM-STEWART-S17S1G1
19 членов
Автор 19 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 6,009
