Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Inspect the damage in the wood and determine how much wood filler will be needed.
Smooth the surface where the damage was by scraping off the splinters using a 50 mm wide putty knife blade.
Use the corner of the blade to smooth over the bumps.
Apply Elmer's Carpenter's Color Change Wood Filler to the putty knife and smear onto the surface.
Sand the dry surface using a 3M 75 mm wide fine-grit sandpaper.
Apply Minwax Wood Finish Stain to the wood using a 25 mm stain brush.
Allow the stain to soak the surface for a few minutes so the wood absorbs it well.
Multiple coats may be applied to reach the desired color.
Dry the surface by patting the surface with a cloth towel.
