How to Repair a Basketball Leak
Выберете то, что вам нужно
  1. How to Repair a Basketball Leak, How to Repair a Basketball Leak: шаг 1, изображение 1 из 3 How to Repair a Basketball Leak, How to Repair a Basketball Leak: шаг 1, изображение 2 из 3 How to Repair a Basketball Leak, How to Repair a Basketball Leak: шаг 1, изображение 3 из 3
    • Locate the leak on the basketball's surface by using one of two methods: the water test or the acoustic test.
    • For the water test, fill a bucket with water, submerge the basketball in the water, and look for bubbles.
    • For the acoustic test, inflate the basketball, hold the ball close to your ear, rotate the ball, and listen for any quiet whistling.
    • The bubbles or quiet whistling noise indicate where air is escaping on the basketball and, therefore, where a leak may be.
  2. How to Repair a Basketball Leak: шаг 2, изображение 1 из 1
    • Once you have found the leak, mark it by placing a small strip of colored tape next to it on the surface of the ball.
  3. How to Repair a Basketball Leak: шаг 3, изображение 1 из 2 How to Repair a Basketball Leak: шаг 3, изображение 2 из 2
    • Clean the leak area of dirt and debris with a clean sponge, soap, and water.
  4. How to Repair a Basketball Leak: шаг 4, изображение 1 из 1
    • Deflate the ball by 20% of the air it currently contains by placing the inflation needle from the ball pump into the inflation hole of the ball until air is released.
    • This will make it easier to place the patch on the ball as it will prevent an excessive amount of air from drying the glue too quickly on the leak area.
  5. How to Repair a Basketball Leak: шаг 5, изображение 1 из 3 How to Repair a Basketball Leak: шаг 5, изображение 2 из 3 How to Repair a Basketball Leak: шаг 5, изображение 3 из 3
    • Use your Slime Tube Patch Kit in the following 4 steps:
    • Take the metal scuffer and sand the leak area.
    • One side of the metal scuffer is very sharp. Be careful to hold the ball so that your fingers are away from the leak area or you could be cut.
    • Apply a thin layer of rubber cement to cover 1 centimeter wider in diameter than the leak area.
    • Place the appropriate sized patch over the whole leak area and gently press it onto the ball's surface.
    • Wait 1 hour for the adhesive to fully dry.
  6. How to Repair a Basketball Leak: шаг 6, изображение 1 из 2 How to Repair a Basketball Leak: шаг 6, изображение 2 из 2
    • Reinflate the basketball.
Заключение
Test your ball to see if the leak has been repaired. If the ball still loses air in a short amount of time, there may be more leaks. Repeat this process to locate and fix them.
Eden Love
Участник с: 03/07/25
133 Репутация
1 руководство автора
Команда
Colorado Springs, Team 1-10, Kiser Spring 2025 Участник Colorado Springs, Team 1-10, Kiser Spring 2025
UCCS-KISER-S25S1G10
1 член
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 44
За последние 30 дней: 168
За всё время: 855
