How to Repair a Broken Hook and Loop Strap
Выберете то, что вам нужно
  1. How to Repair a Broken Hook and Loop Strap, Identify the defect: шаг 1, изображение 1 из 3 How to Repair a Broken Hook and Loop Strap, Identify the defect: шаг 1, изображение 2 из 3 How to Repair a Broken Hook and Loop Strap, Identify the defect: шаг 1, изображение 3 из 3
    • Here we can clearly see the defect: The stitching of the velcro strap is broken.
    • The upper material and the velcro strap are not properly attached anymore.
    • We can repair the strap by using a sewing machine.
  2. How to Repair a Broken Hook and Loop Strap, Prepare the stitching: шаг 2, изображение 1 из 2 How to Repair a Broken Hook and Loop Strap, Prepare the stitching: шаг 2, изображение 2 из 2
    • Check the original seam in terms of thread color, stitching length and pattern.
    • For better results, try to use similar thread color and stitching technique as with the original seam.
    • After having set-up the sewing machine, place the strap onto the needle thread plate.
    • Make sure you can easily move the strap through the needle feed.
  3. How to Repair a Broken Hook and Loop Strap, Start the stitching: шаг 3, изображение 1 из 2 How to Repair a Broken Hook and Loop Strap, Start the stitching: шаг 3, изображение 2 из 2
    • Start the stitching a few mm before the damaged thread to secure it.
    • Use back stitching to prevent the seam from opening.
    • Tip: In-between the stitching, check carefully whether the edges are correctly overlapping.
  4. How to Repair a Broken Hook and Loop Strap, Stitching phase: шаг 4, изображение 1 из 3 How to Repair a Broken Hook and Loop Strap, Stitching phase: шаг 4, изображение 2 из 3 How to Repair a Broken Hook and Loop Strap, Stitching phase: шаг 4, изображение 3 из 3
    • Follow the original seam to cover the stitching holes and ensure a close-to-original look.
  5. How to Repair a Broken Hook and Loop Strap, Finish the stitching: шаг 5, изображение 1 из 2 How to Repair a Broken Hook and Loop Strap, Finish the stitching: шаг 5, изображение 2 из 2
    • Use a back stitching to prevent the seam from opening.
    • Remove the strap carefully from the sewing machine and cut off all the excess seams.
  6. How to Repair a Broken Hook and Loop Strap, Finished and ready!: шаг 6, изображение 1 из 3 How to Repair a Broken Hook and Loop Strap, Finished and ready!: шаг 6, изображение 2 из 3 How to Repair a Broken Hook and Loop Strap, Finished and ready!: шаг 6, изображение 3 из 3
    • 🛠️🏆👏 Congratulations! The repair of the strap is complete, and you're ready to go!
Заключение
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Участник с: 07/19/23
10 230 Репутация
Автор 66 руководств
Команда
INTERSPORT Участник INTERSPORT
Community
25 членов
Автор 169 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 24
За последние 30 дней: 87
За всё время: 1,264
