Введение
If your child's playhouse door has become damaged, use this guide to help you repair it. When exposed to the outdoor elements such as rain and excessive sunshine, paired with overuse by young children, doors and their hinges can become very unstable and break. My guide will show you how to repair the door back to its original working condition.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove all the screws so that each wood panel is separated.
Gather all the individual wood panels and line them up in their numbered order so that the door looks complete.
Attach clamps to the wood panels where the glue was applied. Place one clamp on each end.
Keep the clamps on the wood panels until the glue is completely dry. It takes about 24 hours for the glue to fully cure.
After removing the clamps, use the Phillips screwdriver to put the screws back in the same spots they were removed from.
