Введение
Sometimes the moving about of computer speakers leads to broken wires and the speakers will fail to work properly. This guide will show you how to repair a Harman Kardon CN-04N567-48220 external computer speaker.
Выберете то, что вам нужно
Use your fingers to pull the top of the speaker grill away from the speaker enclosure.
Pull the bottom of the grill away from the speaker enclosure and then completely remove the grill.
Remove the top two 9.5 mm Phillips #1 screws from the speaker.
Remove the two 9.5 mm Phillips #1 screws located below the speaker screws.
Slowly work your way around the seam until the two parts of the enclosure are free.
Inspect both sides of the printed circuit board (PCB) for any raised traces, off-colored areas, or loose components.
Use desoldering braid and a soldering iron to wick away the old solder and wire remnants from the solder pads and through-holes.
Use wire strippers to remove a small section of insulation from the wires.
Use a soldering iron and solder to tin the wires. This prevents the strands from fraying.
Insert the yellow wire into the through-hole marked "R".
Insert the bare ground wire into the through-hole marked "G".
Insert the white wire into the through-hole marked "L".
Reassemble the two parts of the enclosure making sure that the PCB-mounted audio jacks are lined up with the mating holes of the rear enclosure.
8 участников успешно повторили данное руководство.
