Введение
This step-by-step guide will show you how to repair a crack on a Vittorazi Moster 185 Plus MY19 paramotor. The process consists of lossening 5 nuts to remove the cracked exhaust and weld it. In order to be able to remove the nuts, use a 10mm wrench or a 10mm socket with the rachet. As this task could be physically challenging, be sure to know the risk that comes with this project to keep yourself safe from injury.
Выберете то, что вам нужно
Use a 10mm open wrench to lossen the three exhaust mounting points.
Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
