Введение
The Steelcase Cachet swivel chair is a desk chair model that has hollow plastic armrests. When extreme force is applied to these armrests, they can fracture, or even cave in on themselves. If your chair’s armrest has been damaged to this extent, follow the basic instructions in this guide to restore the armrest’s smooth surface and have your armrest safe for use again.
When following this guide, exercise caution while working with broken edges to avoid injury. In addition, be sure to wear protective latex gloves while working with plastic repair putty, as this substance can be toxic. The putty used in this guide does not match the chair to provide a clearer view of the repair process. However, you can purchase putty that matches the chair.
Выберете то, что вам нужно
Use an iFixit Opening Tool to remove the broken piece from your cracked armrest.
Use sandpaper to lightly sand the edges of the broken piece of arm rest.
Remove any remaining debris from the armrest.
Cut or pull off a small section of putty.
Knead the putty in your hands for 30-60 seconds until it is a uniform color.
Set the broken piece back onto the armrest.
Let the putty dry for about 10 minutes.
Apply the plastic putty over the broken piece.
Press putty into any remaining empty spaces.
Let the putty dry for 10 minutes in between applications.
Sand down the putty covering to make the surface smooth and level with the armrest.
2 человек успешно провели ремонт по этому руководству.
