Введение
One day, you turn your Eufy Robovac 15C Max on, and it spins in circles. You've updated the software. You've read about how dark flooring can confuse the Eufy Robovac, but your carpet is the same as ever.
This guide is to disassemble and clean the Eufy Robovac, which will fix erratic or circular driving.
These instructions apply specifically to the Eufy RoboVac 15C Max. Model number: T2128.
Выберете то, что вам нужно
Remove the RoboVac from its charging station.
Flip it onto its back to expose the underside and wheels.
Use a Phillips #1 screwdriver to remove the two 8.2 mm screws from both sides of the slot where the swivel wheel's axle was inserted.
Lift the plastic axle plug from the rest of the RoboVac using the needle-nose pliers.
Clear away any obstructions such as dirt or hair.
Adjust or replace the metal pin as necessary.
Remove the two tri-brush attachments on the RoboVac's underside by prying them up and away from the RoboVac. This is necessary to keep the brushes out of the way.
Use a Phillips #1 screwdriver to remove the eight 7.6 mm screws along the underside of the RoboVac's bumper.
Unplug the connecting cable between the RoboVac and the bumper.
Set the bumper aside.
Инструмент, используемый на этом этапе:Microfiber Cleaning Cloths$3.99
Use a microfiber cloth to clear away any debris.
Ensure that the bumper's two small lever arms spring back when pushed in.
Replace if necessary.
Your Eufy Robovac should be ready to go! Test the device by turning it on.
4 участников успешно повторили данное руководство.
Один комментарий
Is there any way to get a replacement metal clip that holds the swivel wheel in place? mine appears to have broken, and I'm out of warranty.
