How to Repair a Fossilized Dinosaur Tooth with Butvar B-76
Выберете то, что вам нужно
  1. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76, How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 1, изображение 1 из 2 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76, How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 1, изображение 2 из 2
    • Dry fit your fossilized tooth pieces to make sure everything fits accordingly.
    • If available, use photos of the specimen prior to damage as a guide.
  2. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 2, изображение 1 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 2, изображение 2 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 2, изображение 3 из 3
    • Use a metal measuring spoon to scoop around 7 grams of Butvar B-76 plastic resin into a glass beaker.
    • Make sure that the plastic resin is Butvar B-76 and not Butvar B-98 or other Butvar variants which will not work for this procedure.
    • Use a small kitchen scale to weight the Butvar B-76.
    • The amount of Butvar B-76 does not have to be exact.
  3. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 3, изображение 1 из 2 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 3, изображение 2 из 2
    • Put on a pair of nitrile gloves.
    • Handling 100% acetone without gloves can cause skin irritation in the case of accidental spills.
    • Put on a face mask.
    • 100% acetone emits a strong noxious and irritant gas that can be harmful when inhaled.
  4. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 4, изображение 1 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 4, изображение 2 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 4, изображение 3 из 3
    • Take the 100% acetone and carefully fill around 200 milliliters of the liquid into a glass beaker.
    • Do not use impure sources of acetone such as nail polish.
    • Acetone is highly flammable and should be kept away from a source of open flame or heat.
    • Acetone can melt or damage various types of plastics and paint.
    • It is highly recommended the steps from here on out are done in a well-ventilated space.
    • Pour the 200 milliliters of acetone from the glass beaker into a glass jar.
  5. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 5, изображение 1 из 2 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 5, изображение 2 из 2
    • Take the 7 grams of Butvar B-76 and carefully sprinkle the plastic resin into the 200 milliliters of acetone in the jar.
  6. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 6, изображение 1 из 2 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 6, изображение 2 из 2
    • Use a chopstick (or glass stirring rod) and begin mixing the Butvar B-76 and the acetone until the plastic resin has dissolved.
    • You will know that the solution is properly mixed when it is completely clear.
  7. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 7, изображение 1 из 2 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 7, изображение 2 из 2
    • Pour some of the Butvar B-76 solution into a second smaller glass beaker.
  8. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 8, изображение 1 из 2 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 8, изображение 2 из 2
    • Pour the solution from the glass beaker into a plastic dropper bottle.
    • Screw the cap onto the dropper bottle. Make sure it's tightly screwed on.
    • Any excess solution can be poured back into the glass jar or used in the next step.
  9. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 9, изображение 1 из 1
    • This is an optional step if the fossil requires additional stabilization (also known as consolidation) before repair. Proceed with this step if the fossil isn't fragile or crumbling.
    • If the fossil is too fragile or crumbles, move on to Step 11.
    • If the fossil doesn't need to be stabilized or it's not fragile, move on to Step 12.
    • Pour out some of the Butvar B-26 and acetone solution from the glass jar and into a glass beaker
  10. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 10, изображение 1 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 10, изображение 2 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 10, изображение 3 из 3
    • Carefully pick up the fossil with chopsticks (or tweezers).
    • Completely submerge the fossil into the solution. Hold the fossil still in the solution for 30 seconds or until the fossil stops producing bubbles.
    • Be careful to not let your glove touch the solution. It can cause the nitrile glove to weaken and potentially break or tear. Skin contact with the solution can cause irritation.
    • Some purchased specimens may have non-archival glue applied to them, which can partially melt and turn into a messy glob when exposed to acetone.
    • Carefully lift the fossil from the solution and place it on a surface for it to dry.
    • A small piece of cardboard (or any acetone-proof surface) is recommended.
    • Repeat the step for any additional pieces.
    • Wait for the fossil to dry completely before proceeding.
  11. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 11, изображение 1 из 1
    • Only do this step if Step 10 was skipped and your fossil needs to be strengthened before repair. It needs to be strengthened if it's fragile or crumbles.
    • Take an acetone-proof brush and dip it in the Butvar B-76 and acetone solution.
    • Gently brush the solution onto the fossil. Make sure to brush the solution on the entire fossil and any broken pieces from the fossil.
    • Wait for the fossil to dry completely before moving on to the next step.
  12. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 12, изображение 1 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 12, изображение 2 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 12, изображение 3 из 3
    • Hold one fragment of the fossil firmly in one hand.
    • Take the dropper bottle with the solution and drip one drop onto the fossil.
    • Depending on how large the surface area on the fossil is, you may need to drip more drops. Make sure that the solution covers the surface area.
  13. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 13, изображение 1 из 2 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 13, изображение 2 из 2
    • Take the second piece of the fossil and place it onto the first piece. Make sure that both pieces align.
    • Hold both pieces together firmly.
    • Wait 30 seconds to a minute for the solution to completely dry.
  14. How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 14, изображение 1 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 14, изображение 2 из 3 How to Repair a Fossilized Dinosaur Tooth with Butvar B-76: шаг 14, изображение 3 из 3
    • This is an optional step to remove white frost-like film left on the fossil. This is from the Butvar B-76 and acetone solution that had dried on the fossil.
    • Take the 100% acetone and pour some into a glass beaker.
    • Take a acetone-proof brush. Gently brush acetone onto the frost-like film to remove it.
    • Once it's removed, wait for the fossil to dry.
Заключение
The process can be reversed by submerging the specimen in 100% acetone. For fragile or crumbly specimens, this may be difficult or ill-advised.
The Butvar B-76 plastic resin within the solution will last indefinitely for future use, though the acetone itself may evaporate over time even with the lid on and may require occasional refilling. Refer to Step 6 of the guide to re-dissolve the plastic resin if it has solidified from over evaporation.
Еще один человек закончил это руководство.
Iris
Участник с: 09/23/25
244 Репутация
1 руководство автора
Команда
CSU Sacramento, Team 1-21, Laflen Fall 2025 Участник CSU Sacramento, Team 1-21, Laflen Fall 2025
CSUSAC-LAFLEN-F25S1G21
1 член
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 15
За последние 30 дней: 53
За всё время: 315
