How to Repair a Frayed Headphone Cable
Выберете то, что вам нужно
  1. How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: шаг 1, изображение 1 из 2 How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: шаг 1, изображение 2 из 2
    • Cut above the frayed portion of the cable using wire cutters.
    • Using the wire cutters, strip away approximately one inch of wire coating.
    • Use caution to avoid cutting too far into the wire.
  2. How to Repair a Frayed Headphone Cable: шаг 2, изображение 1 из 2 How to Repair a Frayed Headphone Cable: шаг 2, изображение 2 из 2
    • After stripping the wire, four wires should be exposed. The wires should be three different colors.
    • Red: Right channel
    • Gold/copper: Ground
    • Blue/green: Left channel
    • Twist the two ground wires together.
  3. How to Repair a Frayed Headphone Cable: шаг 3, изображение 1 из 2 How to Repair a Frayed Headphone Cable: шаг 3, изображение 2 из 2
    • Unscrew the plug housing.
    • Thread the wire through the plug housing.
  4. How to Repair a Frayed Headphone Cable: шаг 4, изображение 1 из 1
    • Remove the enamel from the red and blue wires with a wire stripper.
  5. How to Repair a Frayed Headphone Cable: шаг 5, изображение 1 из 1
    • With a soldering iron, apply a small amount of solder to the end of each wire.
    • This is especially important for the twisted ground wires; the solder should hold them together.
  6. How to Repair a Frayed Headphone Cable: шаг 6, изображение 1 из 3 How to Repair a Frayed Headphone Cable: шаг 6, изображение 2 из 3 How to Repair a Frayed Headphone Cable: шаг 6, изображение 3 из 3
    • Thread the wires through each hole and wrap them back over.
    • See the third picture for a diagram of where each wire goes.
    • Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
  7. How to Repair a Frayed Headphone Cable: шаг 7, изображение 1 из 2 How to Repair a Frayed Headphone Cable: шаг 7, изображение 2 из 2
    • Solder over each lead's hole, connecting the wire to the lead.
    • Your solder joints should completely cover the hole and surround the wire.
    • After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
  8. How to Repair a Frayed Headphone Cable: шаг 8, изображение 1 из 1
    • Screw the housing back onto the jack and test your work.
    • If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
Финишная черта
36 участников успешно повторили данное руководство.
Tyler
Участник с: 02/24/15
836 Репутация
1 руководство автора
Команда
Cal Poly, Team 23-2, Green Winter 2015 Участник Cal Poly, Team 23-2, Green Winter 2015
CPSU-GREEN-W15S23G2
4 членов
Автор 16 руководств
2 Комментариев
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
Anderson Barreto - Ответить
great instruction - any for repair of cable with microphone ? and even a flat cable ?
LiveVest - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 12
За последние 7 дней: 151
За последние 30 дней: 645
За всё время: 112,811
