Введение
Tired of replacing old headphone sets? Here’s a step-by-step guide on repairing frayed headphone cables in an environmentally efficient and affordable way. This guide will require soldering skills.
Выберете то, что вам нужно
Cut above the frayed portion of the cable using wire cutters.
Using the wire cutters, strip away approximately one inch of wire coating.
After stripping the wire, four wires should be exposed. The wires should be three different colors.
Red: Right channel
Gold/copper: Ground
Blue/green: Left channel
Twist the two ground wires together.
Thread the wires through each hole and wrap them back over.
Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
Solder over each lead's hole, connecting the wire to the lead.
After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
Screw the housing back onto the jack and test your work.
If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
36 участников успешно повторили данное руководство.
2 Комментариев
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
