Введение
Damages on walls can quickly occur through the course of everyday living. Holes on drywalls are unavoidable, and as such, they may need repair before applying paint—this guide list out the steps needed when repairing a hole in the wall. The estimated time to complete the repair is approximately an hour. However, for the layer to dry completely, it might take a day. The repair process is easy, and it is a useful skill that anyone might need( an adult, to be specific).
Use this guide to repair a hole in the wall.
Выберете то, что вам нужно
Prepare the damaged surface by cleaning and removing all dust and debris.
If the surface has a wallpaper, remove it for a length more extensive than the mesh patch.
Apply the self-Adhesive patch by peeling back the paper liner from the patch and apply it over the hole.
Press patch firmly to ensure a strong bond to the wall.
Open container and mix spackling compound before applying.
Mix thoroughly to have a smooth application.
Use the putty knife to spread spackling compound evenly over the adhesive patch.
Spread the spackling mixture beyond the area intended to cover.
Apply thinner layers toward the edges of the patch, so the patched area blends with the wall.
Once the spackling compound has dried, sand it lightly with a sand pad/sponge.
Smooth out any bumps on the surface.
Once the surface is smooth, paint, wallpaper, or apply any texture desire.
2 человек успешно провели ремонт по этому руководству.
