How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing
Выберете то, что вам нужно
  1. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing, Cotton Winter Gloves: шаг 1, изображение 1 из 2 How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing, Cotton Winter Gloves: шаг 1, изображение 2 из 2
    • Find the hole in your glove.
  2. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 2, изображение 1 из 1
    • Using sewing scissors, cut away any loose thread or frayed sections.
    • Removing loose thread or frayed sections will help the sewing process be easier.
  3. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 3, изображение 1 из 1
    • Turn the glove inside out.
    • When the glove is turned inside out, it will ensure that the stitching from the repair won't be seen on the outside.
  4. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 4, изображение 1 из 1
    • Cut about 24 inches of thread with a color that matches your gloves.
  5. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 5, изображение 1 из 1
    • Hold the needle with your thumb and index finger.
    • Insert one end of the thread into the eye of the needle.
    • Pull the thread through the needle about halfway.
    • Working with sewing needles can potentially result in a minor injury.
  6. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 6, изображение 1 из 2 How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 6, изображение 2 из 2
    • Find both ends of the thread.
    • Line the ends of the thread together.
    • Create a knot at the end of the thread.
  7. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 7, изображение 1 из 1
    • Using your dominant hand, insert the needle as close to the edge of the hole as possible.
    • Pull the needle and all of the thread through the glove.
  8. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 8, изображение 1 из 2 How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 8, изображение 2 из 2
    • Thread the needle to the other side of the glove to create a straight stitch.
    • Repeat steps 7 and 8 until you reach the other end of the hole.
    • How to Sew a Straight Stitch
  9. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 9, изображение 1 из 1
    • Insert 3/4 of the needle into the glove.
  10. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 10, изображение 1 из 1
    • Wrap the thread around the needle 3 times.
  11. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 11, изображение 1 из 1
    • Pull the needle and thread through to make a knot.
  12. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 12, изображение 1 из 1
    • Cut the excess thread off.
  13. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: шаг 13, изображение 1 из 1
    • Turn the glove around and wear the glove!
Заключение
4 участников успешно повторили данное руководство.
Jessie Li
Участник с: 02/21/22
337 Репутация
1 руководство автора
Команда
University of North Texas, Team 1-9, Smith Spring 2022 Участник University of North Texas, Team 1-9, Smith Spring 2022
UNT-SMITH-S22S1G9
1 член
Автор 1 руководств
Один комментарий
I found a typo.
On step 8, it says, "Thread the needle to the other side of the glove." This doesn't make sense. Did you mean PUSH the needle?
You already covered threading the needle in step 3. It's not possible to "thread a needle to the other side" of something.
Jean - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 58
За всё время: 3,515
