How to Repair a Hole in Workout/Yoga Around the Groin
Выберете то, что вам нужно
  1. How to Repair a Hole in Workout/Yoga Around the Groin, How to Repair a Hole in Workout/Yoga Around the Groin: шаг 1, изображение 1 из 1
    • Take the pants and put them inside out.
    • You want the seams to be showing.
  2. How to Repair a Hole in Workout/Yoga Around the Groin: шаг 2, изображение 1 из 1
    • Take the sewing pins (if the hole is big) and pin closed along the seam.
    • This should take no more than 5 pins to do.
  3. How to Repair a Hole in Workout/Yoga Around the Groin: шаг 3, изображение 1 из 3 How to Repair a Hole in Workout/Yoga Around the Groin: шаг 3, изображение 2 из 3 How to Repair a Hole in Workout/Yoga Around the Groin: шаг 3, изображение 3 из 3
    • Take the thread (make sure it is the preferred color that matches the pants) and thread it through the needle.
    • Make sure to leave a large tail at least 20 inches.
    • Tie the two ends together into a small knot.
  4. How to Repair a Hole in Workout/Yoga Around the Groin: шаг 4, изображение 1 из 1
    • Insert the needle into the fabric from one side until you can see the needle on the other side.
    • Pull all the way through.
  5. How to Repair a Hole in Workout/Yoga Around the Groin: шаг 5, изображение 1 из 1
    • Take the needle and put it back through the fabric a short distance from where it came out originally.
  6. How to Repair a Hole in Workout/Yoga Around the Groin: шаг 6, изображение 1 из 1
    • Continue steps 7 and 8 until you have reached the other end of the hole.
  7. How to Repair a Hole in Workout/Yoga Around the Groin: шаг 7, изображение 1 из 2 How to Repair a Hole in Workout/Yoga Around the Groin: шаг 7, изображение 2 из 2
    • Once you have finished sewing the hole, take the thread and tie a small knot at the base of the thread.
    • Cut thread and reverse the pants to check the seam.
  8. How to Repair a Hole in Workout/Yoga Around the Groin: шаг 8, изображение 1 из 1
    • If seam is completely closed, then you have done it!
    • If not, then repeat steps 7-11 until hole is completely closed.
Заключение
If seam is completely closed, then you have done it! If not, then repeat steps 7-11 until hole is completely closed.
Jessy Sternblitz
Участник с: 09/20/23
157 Репутация
1 руководство автора
Команду
University of North Texas, Team 1-19, Martin Fall 2023 Участник University of North Texas, Team 1-19, Martin Fall 2023
UNT-MARTIN-F23S1G19
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 7
За последние 30 дней: 17
За всё время: 251
