How to Repair a Hole in a Duvet Insert
Выберете то, что вам нужно
  1. How to Repair a Hole in a Duvet Insert, How to Repair a Hole in a Duvet Insert: шаг 1, изображение 1 из 1
    • Remove the duvet cover from the insert and locate the hole.
  2. How to Repair a Hole in a Duvet Insert: шаг 2, изображение 1 из 1
    • Cut a piece of scrap fabric slightly larger than the hole.
  3. How to Repair a Hole in a Duvet Insert: шаг 3, изображение 1 из 1
    • Insert the fabric inside the hole, making sure the fabric covers the entirety of the opening.
  4. How to Repair a Hole in a Duvet Insert: шаг 4, изображение 1 из 1
    • Carefully pin the patch in place, ensuring the entire opening is covered and secure.
  5. How to Repair a Hole in a Duvet Insert: шаг 5, изображение 1 из 1
    • Insert thread in the needle hole and tie a slip knot at the end of the thread.
    • Keep extra thread pulled through the needle to prevent it from unthreading. If it does, re-thread and continue.
  6. How to Repair a Hole in a Duvet Insert: шаг 6, изображение 1 из 3 How to Repair a Hole in a Duvet Insert: шаг 6, изображение 2 из 3 How to Repair a Hole in a Duvet Insert: шаг 6, изображение 3 из 3
    • Insert the needle in one of the corners of your patch, being sure to pierce through both the duvet insert and patch.
    • Continue stitching around the perimeter of the patch with stitches around 1/4 of an inch long until you have reached your previous starting point.
  7. How to Repair a Hole in a Duvet Insert: шаг 7, изображение 1 из 2 How to Repair a Hole in a Duvet Insert: шаг 7, изображение 2 из 2
    • Sew around the hole's edges to secure the duvet insert into the patch to prevent future tearing.
  8. How to Repair a Hole in a Duvet Insert: шаг 8, изображение 1 из 3 How to Repair a Hole in a Duvet Insert: шаг 8, изображение 2 из 3 How to Repair a Hole in a Duvet Insert: шаг 8, изображение 3 из 3
    • Once finished, tie 1-2 knots and cut the thread off.
    • Make sure to leave 1/4 inch between the cut and the knot to prevent the knot from coming undone.
Финишная прямая
2 человек успешно провели ремонт по этому руководству.
Ben Arnold-Galati
Участник с: 11/05/24
187 Репутация
1 руководство автора
Команда
UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 Участник UC Davis, Team 3-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G3
3 членов
Автор 2 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 24
За всё время: 237
