Введение
If you ever need to fix a shirt on the go. or just needing it fix this is the guide for you!!
Выберете то, что вам нужно
Find the hole in the shirt. Spread out the shirt where hole is but don't spread the hole.
After you have found the hole put your hand underneath. Get the needle and thread and from underneath the shirt, start putting the needle through the shirt.
When you have the needle through you will need to stitch the hole close from the inside by going in out of the fabric.
After the hole is closed by stitching it. You will need to go back over the top of the hole called the seem and sew that down flat.
After the seem is sewn down you do a topstitch which is just a tighter neater regular stitch. After you get the end you will need to to tie a knot and cut the thread.
Here what it is supposed to look like and it is best if you wash the shirt but it doesn't not hurt if you don't.
Еще один человек закончил это руководство.
