Введение
Do you have a pair of shoes or just one shoe with a hole on the shoe sole? With this guide, you will be able to repair the hole and reuse the shoe rather than buying a new pair.
Выберете то, что вам нужно
Clean the outsole with a wet paper towel.
Clean and dry the outsole with a paper towel before starting.
Pull the insole out of the shoe.
Apply duct tape inside the shoe (on the other side of the hole).
Make sure the duct tape covers up the entire hole, so there will be no shoe goo going through the sole into the shoe.
After 24 hours, remove the duct tape from the shoe.
Place the insole back into the shoe.
Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth.
Now you can walk again!
31 человек успешно провели ремонт по этому руководству.
11 Комментариев
Excellent - thank you
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
