How to Repair a Large Wall Hole Using Drywall
Выберете то, что вам нужно
  1. How to Repair a Large Wall Hole Using Drywall, How to Repair a Large Wall Hole Using Drywall: шаг 1, изображение 1 из 2 How to Repair a Large Wall Hole Using Drywall, How to Repair a Large Wall Hole Using Drywall: шаг 1, изображение 2 из 2
    • Measure the distance between the nearest studs on either side of the hole using a tape measure.
    • Trace a rectangular/square shape around the hole in pencil.
    • Use a box cutter to cut along the lines, making the hole into an even rectangular/square shape.
  2. How to Repair a Large Wall Hole Using Drywall: шаг 2, изображение 1 из 1
    • Use the tape measure to measure the drywall to fit the dimensions of the hole trimmed in Step 1.
    • Cut out the section of drywall with the box cutter.
    • Measure out the two pieces of wood using the tape measure. These strips of wood should be just a few inches longer than the length of the hole.
    • Cut the pieces of wood to the desired length with the hand saw.
  3. How to Repair a Large Wall Hole Using Drywall: шаг 4, изображение 1 из 1
    • Place the two pieces of wood vertically inside the hole.
    • Use a Phillips flat head drill bit to drill 6x2 mm drywall screws into the two pieces of wood to the inside of the hole.
  4. How to Repair a Large Wall Hole Using Drywall: шаг 5, изображение 1 из 2 How to Repair a Large Wall Hole Using Drywall: шаг 5, изображение 2 из 2
    • Place the section of drywall you cut in Step 2 into the hole.
    • The section of drywall should fit inside the hole snugly. The margins do not have to fit perfectly, but there should be no larger than a 1/8 inch gap between the dry wall and the edges of the hole.
    • Screw the drywall into the pieces of wood.
    • Make sure to screw in the corners of the drywall to ensure stability.
  5. How to Repair a Large Wall Hole Using Drywall: шаг 6, изображение 1 из 1
    • Cut pieces of drywall mesh tape so that they will cleanly cover the gaps between the drywall and the hole.
    • Apply the pieces of dry wall mesh tape to the seams.
  6. How to Repair a Large Wall Hole Using Drywall: шаг 7, изображение 1 из 1
    • Apply drywall filler over the mesh tape and the holes left by the screws using a putty knife.
  7. How to Repair a Large Wall Hole Using Drywall: шаг 8, изображение 1 из 1
    • After the surface is completely dry, smooth out the wall with sandpaper.
    • Paint the wall the color of your choice.
Финишная черта
Mustafa
Участник с: 09/18/20
145 Репутация
1 руководство автора
Команда
York University, Team S3-G62, Melo-Thaiss Fall 2020 Участник York University, Team S3-G62, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G62
1 член
Автор 1 руководств
Один комментарий
Thanks for this detailed piece of information! I like this post.
Century Drywall - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 39
За всё время: 1,147
