Введение
If you're an avid cyclist or even a casual rider, you may have experienced a loose rear bicycle wheel at some point. Riding with a wobbly or unstable wheel can be dangerous and potentially cause damage to your bike or even result in an accident. But don't worry, repairing a loose rear bicycle wheel is a relatively simple process that can be done with a few basic tools and some patience.
In this guide, we'll go over the step-by-step process for repairing a loose rear bicycle wheel. We'll cover how to loosen the rear axle, remove the wheel, assess the damage, properly set the wheel back into the dropout, and check for alignment issues. By following these steps, you'll be able to fix a loose rear bicycle wheel and get back on the road safely in no time.
So, let's get started with our guide on how to repair a loose rear bicycle wheel.
Выберете то, что вам нужно
Loosen the rear axle.
Turn the bike around, and loosen the brake arm.
Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
Один комментарий
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
