Введение
Over time, snow globes can loosen or completely separate from their base. Some snow globes are irreplaceable; they could be limited edition, or simply have sentimental value. Buying a snow globe can also be quite expensive. Therefore, this beginner-friendly guide can help people fix their loose snow globe base using simple tools without any past repair experience.
Выберете то, что вам нужно
Place your snow globe in a heat-resistant bowl.
Boil some water, then pour it in the bowl until it covers the top of the snow globe’s base.
Leave the snow globe in the water for about a minute to loosen the adhesive.
Remove the snow globe from the bowl and twist the snow globe counterclockwise from its base to separate the base from the globe.
If the globe is not easily separating from the base, place it back in the boiling water for one more minute and then try again. Repeat as many times as necessary.
Heat your glue gun and apply a thin layer of hot glue on the bottom of the snow globe and the base.
Your snow globe's base should be sturdy again!
