Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Find colored thread to match the color of the lunch bag and a needle.
Gather thread that is 3 to 4 times the length of the part that needs to be sewn. Measure 18 inches of thread and double it.
Cut the thread to match the length of the ruler.
Loop one end of the thread through needle.
Move the needle to the middle of the thread to have even amounts of thread on each side.
Tie knot at the end of string and repeat 3x. Try to place all knots in the same place.
Thread the needle through the lunchbox and handle. Pull all the way through, until the knot stops. Start on the inside, so the knot is not visible at the end. Stick the needle the opposite direction, about a ¼” away from the first stitch. Leave room between your first and second stitch.
Thread the needle back through the lunchbox and handle in the space between your first and second stitch.
Continue to stitch every other space, until you have sewed the handle back in place.
To end the last stitch, thread the needle between the lunchbox and thread of your last stitch. Rather than pulling the thread completely through, thread the needle back through the excess thread to make a knot.
You can continue looping the needle about the thread to make the knot extra secure.
Trim the excess thread as short as possible to make the stitches look clean and to avoid snagging. Your bag should now be good as new!
Еще один человек закончил это руководство.
