Введение
You will be fixing a torn ribbon choker and replacing the crimps and clasps with a new one. To accomplish this replacement, you will be cutting off the teared fabric and reclasping new crimps onto the ends to repair the ribbon choker.
Выберете то, что вам нужно
Use a pair of scissors to cut right before the tear.
Cut off the crimp on the other end.
Using the long nose pliers, place the new crimp to the end of the ribbon and squeeze the crimp shut.
Using the long nose pliers, open up the circular ring attached to the new clasp.
Place the open ring on the crimp by putting it through the hole on the end of the choker.
Using your fingers, secure the clasp by squeezing and closing the ring shut.
Place the open ring on the crimp by putting it through the hole on the end.
Using either the long nose pliers or your hands, secure the ring of the chain to the other side of the crimp.
Test out your new choker by putting it on.
When wearing the choker, make sure that the crimp, clasp and chain is secure.
You can apply this guide to repair a different size ribbon choker. This guide can also be used to make a DIY choker using a new ribbon.
Еще один человек закончил это руководство.
