How to Repair a Squier Affinity Stratocaster Guitar Jack
Выберете то, что вам нужно
  1. How to Repair a Squier Affinity Stratocaster Guitar Jack, Input Jack: шаг 1, изображение 1 из 1
    • Test the sound output via amplifier, and then set it to zero.
    • Keeping the amplifier on with the guitar connected to it may produce unpleasant static depending on how loose the jack is. Make sure to turn it off before proceeding.
  2. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 2, изображение 1 из 1
    • Using the Phillips #3 screwdriver, remove the two 1.2 mm screws that are connected to the plate.
  3. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 3, изображение 1 из 1
    • Remove the plate without touching the jack.
    • Fixing the jack without removing the plate can cause broken wires. Do not tighten the bolt connecting the jack before taking off the plate.
  4. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 4, изображение 1 из 3 How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 4, изображение 2 из 3 How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 4, изображение 3 из 3
    • Take the jack out of the guitar.
    • Here, you can examine the wires and check for any interior damages.
  5. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 5, изображение 1 из 1
    • Carefully tighten the outside of the jack using a wrench.
    • If you do not have an adjustable wrench, use an ESP Multi Spanner.
  6. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 6, изображение 1 из 1
    • Carefully reconnect the plate back on using your screwdriver.
  7. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 7, изображение 1 из 1
    • Readjust the output settings on your guitar, and plug in your audio cable.
  8. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 8, изображение 1 из 1
    • Test the tightness of your input jack before plugging your audio cable into your amplifier.
  9. How to Repair a Squier Affinity Stratocaster Guitar Jack: шаг 9, изображение 1 из 1
    • Plug the guitar into the amplifier to test the audio cable sensitivity and output quality.
Заключение
That is all you need to do to fix your Squier Affinity Stratocaster’s input jack. Now have fun making music!
5 человек успешно провели ремонт по этому руководству.
Maryam Ahmed
Участник с: 05/12/21
327 Репутация
1 руководство автора
Команда
York University, Team S1-G2, Melo-Thaiss Summer 2021 Участник York University, Team S1-G2, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G2
1 член
Автор 2 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 17
За последние 30 дней: 80
За всё время: 5,344
